TRVAControlPanel.UseTextCodePageDialog |
Top Previous Next |
Specifies whether the file-related actions can display a dialog for choosing a text file codepage. property UseTextCodePageDialog: Boolean; This property affects the following actions: It affects loading and saving text files in the editor containing Unicode text. If False, non-Unicode text files are saved using the system-default code page; a code page for insertion is taken from the Charset of the current text. If True, a dialog for choosing a code page is displayed (the saving and exporting actions display this dialog only if the document is completely in Unicode). In addition to ANSI code pages, it allows choosing UTF-8 and UTF-16. Default value: True |
