TrvActionTableProperties.StoreImageFileName
Top  Previous  Next
Specifies whether file names (full paths) are stored for background image of table and cells assigned by this action.
property StoreImageFileName: Boolean;
If this property is True, path to the graphic file is stored in the document:
in the rvespImageFileName item property (see the RichView help file, TRVExtraItemStrProperty type) for tables;
in BackgroundImageFileName cell property for table cells.
This is a recommended way to store path to graphic files. You can use these file names when saving HTML files (Include rvsoUseItemImageFileNames in TrvActionSave.SaveOptions and TrvActionExport.SaveOptions).
Default value
False
See also:
TrvActionPasteSpecial.StoreFileName
TrvActionInsertPicture.StoreFileName
TrvActionItemProperties.StoreImageFileName
TCustomRichView.RTFReadProperties.StoreImagesFileNames
HTML Import (for images inserted with HTML, paths to graphic files are always stored in rvespImageFileName)
RichView © Sergey Tkachenko
