SRVGetRichViewEditFromPopupComponent Function |
Top Previous Next |
Allows TRVAPopupMenu component working with TSRichViewEdit. Unit SclRView. function SRVGetRichViewEditFromPopupComponent( PopupComponent: TComponent): TCustomRichViewEdit; Use this function is you use RichViewActions, specifically TRVAPopupMenu component (or its third-party analogs). This function must be assigned to RVA_GetRichViewEditFromPopupComponent variable defined in RichViewActions.pas: RVA_GetRichViewEditFromPopupComponent := SRVGetRichViewEditFromPopupComponent; Assign this variable before the first use of TRVAPopupMenu component. For example, it can be assigned in OnCreate event of the main form, or in the initialization section. See also: •SRVGetRichViewEdit function |
