TSRichViewEdit.Destroy |
Top Previous Next |
Disposes of the component. destructor Destroy; override; Do not call Destroy directly. Call Free instead. Free verifies that the component is not nil, and only then calls Destroy. Never explicitly free a component in one of its own event handlers, nor free a component from the event handler of a component that it owns or contains. Note: A form owns all the controls and non-visual components that are placed on it in design mode. When it is freed, all of these components are automatically freed as well.
