TSRichViewEdit.GetFirstItemVisibleRV |
Top Previous Next |
Returns the first visible item. procedure GetFirstItemVisibleRV(var RVData: TCustomRVFormattedData; var ItemNo, OffsetInItem: Integer); This function returns the position where the caret would be placed if the user clicked at the top left corner of TSRichViewEdit control's window. RVData is a document (RichViewEdit.RVData, table cell, or cell inplace editor's RVData), ItemNo is an index of item in this document, OffsetInItem is a position inside this item. See also: |
