TSRichViewEdit.GetPageAt |
Top Previous Next |
Returns the page at the specified coordinates. function GetPageAt(X, Y: Integer; var PageNo: Integer) : Boolean; Input parameters: X, Y – client coordinates (relative to the top left corner of TSRichViewEdit component's window) Output parameter: PageNo – index of page, from 1. Valid only if the method returns True. Return value: True if the position is inside a page. |
