Bad RTF table causing RichView to error
Re: Bad RTF table causing RichView to error
One clarification I believed initially this was RTF table related, it is not nothing to do with RTF. I am sorry for that confusion.
The error occurs on drawing a document (not a background), and the only reason I can imagine is desynchronization between the document items and formatting information (the latter is updated when you call Format).
In your code, the most probable reason for this is
This method may remove some unnecessary document items.
You need to call Format after it, not before.
reader.RVData.NormalizeDocument(0,True)
This does seem to work thank you.
reader.RVData.NormalizeDocument(0,True);
reader.format;
