copy current col to a new current col
j&b
Post by j&b »
Hello Sergey,
many thanks.
Your procedure runs very fine.
But only in the same table. But I want to copy to another table too.
For this reason I splitted your procedure in 2 procedures:
- in a copying procedure (SpalteKopierenClick) and
- in a pasting procedure (SpalteEinfuegenClick)
My splitted procedure work.
So I can copy the 2. column of Table and/or pasting in the 5. column.
Only one little thing is wrong ;-):
The 2. procedure copies either all cell-contents of source-col into each cell of dest-col
or only the last cell-content of source-col into each cell of dest-col.
No wonder. You selects a cell and write her immediately into the dest-cell of the same rveTable then you freed Stream1(.free) and creates stream1 new (stream1:= TMemoryStream.create). Stream1 contains only the contents of one cell.
Can you correct my mistake ?
Jürgen
procedure TForm1.SpalteKopierenClick(Sender: TObject);
var r: integer;
    UnusedColor: TColor;
    oldps, oldts:TRVFReaderStyleMode;
  if (not memo.CanChange) or (not memo.GetCurrentItemEx(TRVTableItemInfo, rve, TCustomRVItemInfo(rveTable))) then begin
    ShowMessage('Tabelle hat nicht den Focus.');
  rveTable.GetEditedCell(r, rveTspalte);
  { private:
      rveTspalte: integer;
      rveTable: TRVTableItemInfo;
      stream1: TMemoryStream;
  UnusedColor := clNone;
  oldps := memo.RVFParaStylesReadMode;
  oldts := memo.RVFTextStylesReadMode;
  memo.RVFParaStylesReadMode := rvf_sIgnore;
  memo.RVFTextStylesReadMode := rvf_sIgnore;
  SendMessage(memo.Handle, WM_SETREDRAW, 0, 0);
    stream1.Clear; //--> all cell-contents of source-col shall copied to each cell of selected dest-col
    for r := 0 to rveTable.Rows.Count-1 do
      if rveTable.Cells[r, rveTspalte]<>nil then begin
        //stream1.clear;  //only the cell-content of last source-col shall copied to each cell of selected dest-col
        rveTable.Cells[r, rveTspalte].GetRVData.SaveRVFToStream(Stream1, False, UnusedColor, nil, nil);
    memo.RVFParaStylesReadMode := oldps;
    memo.RVFTextStylesReadMode := oldts;
    SendMessage(memo.Handle, WM_SETREDRAW, 1, 0);
    if memo.InplaceEditor<>nil then memo.InplaceEditor.Invalidate;
    //while memo.InplaceEditor<>nil do memo.InplaceEditor.Invalidate;  //loop without exit
procedure TForm1.SpalteEinfuegenClick(Sender: TObject);
var r, rveTspalte2: integer;
  rveTable.GetEditedCell(r,rveTSpalte2);
      if rveTable.Cells[r, rveTspalte2]<>nil then begin
        Stream1.Position := 0;
        rveTable.Cells[r, rveTspalte2].Edit;
        memo.TopLevelEditor.SelectAll;
        memo.TopLevelEditor.InsertRVFFromStreamEd(Stream1);
  if table1.state in [dsEdit, dsInsert] then table1.post;
Your procedure saves the first cell to the stream, then clears the stream and saves the second cell, and so on. So, of course, only the last cell remains in the stream.
Is it necessary to implement it as two procedures?
It would be simpler to make a procedure
procedure CopyTableColumnEd(rv: TCustomRichViewEdit; SourceTable, DestTable: TRVTableItemInfo; SourceCol, DestCol: Integer);
copying the SourceCol-th column of SourceTable to the DestCol column of DestTable.
j&b
Post by j&b »
Hello Sergey,
thank you for your quick answer.
User click in one col of table1. Then he choose another table clicks in a col.
I have tried it with
CopyTableColumnEd(rve: TCustomRichViewEdit; rveTable,rveTable2: TRVTableItemInfo; SourceCol, DestCol: Integer);
I get the same result. I can only copy a col of the 2. table to another col of the same table
I believe that I know the mistake.
I only get the col-no of table1 and table2.
In CopyTableColumnEd procedure rveTable is the same as rveTable2. Correct ?
  var r: integer;
  rveTable2.GetEditedCell(r,rveTSpalte2);
  CopyTableColumnEd(memo, rveTable,rveTable2, rveTspalte,rveTspalte2);
procedure TForm1.CopyTableColumnEd(rve: TCustomRichViewEdit; rveTable,rveTable2: TRVTableItemInfo; SourceCol, DestCol: Integer);
var r: Integer;
  oldps := rve.RVFParaStylesReadMode;
  oldts := rve.RVFTextStylesReadMode;
  rve.RVFParaStylesReadMode := rvf_sIgnore;
  rve.RVFTextStylesReadMode := rvf_sIgnore;
  SendMessage(rve.Handle, WM_SETREDRAW, 0, 0);
      if (rveTable.Cells[r, SourceCol]<>nil) and (rveTable2.Cells[r, DestCol]<>nil) then begin
        stream1.Clear;
        rveTable.Cells[r, SourceCol].GetRVData.SaveRVFToStream(Stream1, False, UnusedColor, nil, nil);
        rveTable2.Cells[r, DestCol].Edit;
        rve.TopLevelEditor.SelectAll;
        rve.TopLevelEditor.InsertRVFFromStreamEd(Stream1);
    rve.RVFParaStylesReadMode := oldps;
    rve.RVFTextStylesReadMode := oldts;
    SendMessage(rve.Handle, WM_SETREDRAW, 1, 0);
    while rve<>nil do begin
      rve.Invalidate;
      rve := TCustomRichViewEdit(rve.InplaceEditor);
There is a misprint in your code. In both procedures, you call GetCurrentItemEx for rveTable, instead of calling it for rveTable and rveTable2.
Otherwise your code is ok, but several problems are possible:
1) Even if the table is active, it's not necessary that it has an edited cell. There are may be multicell selection or caret after/before the table.
Solution: check the result of GetEditedCell and display an error message if it is nil.
2) User may delete columns of rveTable before clicking SpalteEinfuegen.
Solution: in CopyTableColumnEd, check
if rveTable.Rows[0].Count<=SourceCol then begin
  <display error>
3) Tables may have different number of rows.
Solution: the cycle for r := 0 to rveTable.Rows.Count-1 do must be not to rveTable.Rows.Count-1 but to min(rveTable.Rows.Count, rveTable2.Rows.Count)-1.
4) User may delete rveTable before clicking SpalteEinfuegen.
Solution: process OnItemAction event, and if the ItemAction parameter is equal to rviaMovingToUndoList or rviaDestroying, assign rveTable := 0.
In SpalteEinfuegenClick, check:
if rveTable=nil then begin
    <display error message: the source table is not specified>
