Ok, got it work with RichView.OnImportPicture.
But it seems OnImportPicture fires twice for the same picture. Why?
Paste HTML using pBear HtmlImport
In the current implementation, images are loaded sequentially, one by one.
When the parser encounters an image, it invokes the event for loading this picture, and waits while you load/download the picture in this event, then inserts it in TRichView.
However, you can implement threaded loading. But you need to do it yourself.
In OnImportPicture, you need to return a placeholder (some temporal picture) and create a thread for downloading. When the picture is downloaded, replace this placeholder to the downloaded picture.
A couple years ago I created a demo for TrvHtmlImporter: http://trichview.com/resources/html/rvh ... hreads.zip
You can use it as a base for your code.
