[How to] How to use PNG and GIF images in TRichView
There are no procedures for unregistering. Everything is cleaned up when the application exits.
The first message in this topic is updated for compatibility with TRichView 14.5+:
- now, TRichView uses TPngImage automatically in Delphi 2009+ (unless you define RVDONOTUSEPNGIMAGE in RV_Defs.inc)
- RVGraphicHandler should be used instead of the old functions
Re: [How to] How to use PNG and GIF images in TRichView
This information is useful for users of Delphi 2007 and older. New versions of Delphi have a built-in TPngImage class, it is supported by TRichView automatically.
Once again about using TPngObject.
Information in the first post of this topic describes all necessary steps except for allowing high-quality resizing for PNG images.
You need to add code allowing thumbnails (high-quality sizing) for TPngObject.
The complete initialization code for TPngObject is:
uses
  PngImage, RVGrHandler, RVThumbMaker;
type
  TMyGraphicHandler = class (TRVGraphicHandler)
  public
    function IsTransparent(Graphic: TGraphic): Boolean; override;
function TMyGraphicHandler.IsTransparent(Graphic: TGraphic): Boolean;
  if Graphic is TPNGObject then
    Result := Graphic.Transparent
    Result := inherited IsTransparent(Graphic);
procedure InitPngObject;
  RVGraphicHandler.Free;
  RVGraphicHandler := TMyGraphicHandler.Create;
  RegisterClass(TPngObject);
  RVGraphicHandler.RegisterHTMLGraphicFormat(TPngObject);
  RVGraphicHandler.RegisterPngGraphic(TPngObject);
  RVThumbnailMaker.AllowThumbnailsFor(TPNGObject);
initialization
  InitPngObject;
