Printing isn't correct on every printers
I use 1.9.24 and made the changes.Sergey Tkachenko wrote:These changes are included in TRichView 1.9.25, but it cannot work with tables in RB reports, so add them manually in your copy of TRichView.
It don't work with tables in RB reports.
When tables in RB reports will be supported in current version?
What is the newest version supporting table in RB reports? Where can'I donwload it?
We are seriously waiting a finalised version where all RV features work with RB report.
We can't deal with a mix of old version and patchs.
And there is still a problem with TExtraDevice PDF export. I has worked with older version, but since the fix for print output it don't work.
First, thank you for update of TRichView.
But I advised your component for SOLUNE application, We spent much time to integrate it and now we are blocked.
We are conscious of carried out work, but the future of the application (SOLUNE) depends on the correct operation of this component.
Could you inform us on the time for the corrections of the bugs mentioned above ?
Regards
Jean-Philippe RENOU
Regards
Jean-Philippe RENOU
JPR, if you are waiting for this fix ("RB wrapper prints badly on some printers") you can use the fixed version of RB wrapper with TRichView v1.9.24 (last stable version), after making fixes in trichview code mentioned above (21 Oct 2006). So you can use it already today.
As for the latest alpha version, it will work with RB wrapper after implementing saving and reading page in RVF format. I'll try to do it this weekend.
RB7 wrapper is uploaded, you can see links in the same "Announcement" forum, "Latest versions" topic.
For the alpha version of TRichView, the wrapper is here:
http://www.trichview.com/resources/repo ... rvrb7b.zip
