Table -> Cell[c,r] -> selectAll
Denoson
Post by Denoson »
I need to select all value of table cell.
  if not EDITOR.CanChange or
     not EDITOR.GetCurrentItemEx(TRVTableItemInfo, rve, item) then exit;
  table := TRVTableItemInfo(item);
  if table.GetEditedCell(r,c)<>nil then
    table.Cells[r,c].SelectAll;
    Caption := 'Cell: ' + inttostr(r) + ', ' + inttostr(c);
Edit-cell is detected (Row and Column), but text is not selected.
  if not EDITOR.GetCurrentItemEx(TRVTableItemInfo, rve, item) then exit;
    table.Cells[r,c].GetRVData.SelectAll;
    table.Cells[r,c].GetRVData.Invalidate;
When the cell is edited, all cell items are moved to the cell inplace editor.
Its content is available as Cell.GetRVData.
Also, I removed CanChange, because this code does not modify document.
Denoson
Cells
Post by Denoson »
I try new code, but:
table.Cells[r,c].GetRVData. - has no SelectAll and Invalidate methods :(
Denoson
Cells
Post by Denoson »
Hello Sergey, any news about Cells->Select all?
    TCustomRVFormattedData(table.Cells[r,c].GetRVData).SelectAll;
    TCustomRVFormattedData(table.Cells[r,c].GetRVData).Invalidate;
Denoson
Cells -> Select all
Post by Denoson »
Thanks this code works well.
