copy text from the cursor
how to do to select all the text from the point of the strokes down?
Re: copy text from the cursor
hello, I insist, how can I do to copy the text programmatically from the point where the cursor is located by copying all the text below the cursor?
Sorry for the delay.
And sorry, I do not understand your question.
Do you want to copy to the Clipboard all text from the blinking caret position and to the end of the document?
Or may be you want to copy a word below the pointer?
Or something else?
Or something else?
exactly, i need to copy all the text from the blinking cursor down. example:
AAAAAAAAAA
BBBBBBBBBB
CCCCCCCCC
DDDDDDDDD
FFFFFFFFFFF
GGGGGGGG
suppose user placed the cursor at the beginning of "ACPC" I need to copy to a secondary TSrichView from "CCC ..." to "GGGG ..."
or if there are more pages after "GGGG" to copy as well.
thanks
AAAAAAAAAA
BBBBBBBBBB
CCCCCCCCC
DDDDDDDDD
FFFFFFFFFFF
GGGGGGGG
thanks
I suggest to select the fragment that you need to copy temporarily, then restore the original selection.
To prevent flickering, do it in BeginUpdate/EndUpdate.
Let we have rve: TRichViewEdit.
uses
RVLinear;
SelStart, SelLength: Integer;
RVGetSelection(rve, SelStart, SelLength);
rve.BeginUpdate;
rve.SetSelectionBounds(rve.CurItemNo, rve.OffsetInCurItem, rve.ItemCount-1, rve.GetOffsAfterItem(rve.ItemCount-1));
rve.CopyDef;
RVSetSelection(rve, SelStart, SelLength);
rve.EndUpdate;
If you need to copy not to the clipboard but to another editor rve2:
The same code for ScaleRichView, copying from srv to srv2:
uses
RVLinear;
Stream: TMemoryStream;
rve.BeginUpdate;
rve.SaveRVFToStream(Stream, False);
rve.EndUpdate;
Stream.Position := 0;
rve2.LoadRVFFromStream(Stream);
rve2.Format;
Stream.Free;
uses
RVLinear;
RVGetSelection(srv.RichViewEdit, SelStart, SelLength);
srv.CanUpdate := False;
with srv.RichViewEdit do
SetSelectionBounds(CurItemNo, OffsetInCurItem, ItemCount-1, GetOffsAfterItem(ItemCount-1));
srv.RichViewEdit.SaveRVFToStream(Stream, False);
RVSetSelection(srv.RichViewEdit, SelStart, SelLength);
srv.CanUpdate := True;
srv2.RichViewEdit.LoadRVFFromStream(Stream);
srv2.Format;
Stream.Free;
please friend, I insist that you read and see the examples I gave you, I need to copy only where the cursor is flashing on the screen until the end and not the entire text, I think the translation is getting bad because I don't think it you haven't understood.
"your code copies the entire text from and not just that of the blinking cursor down."
in my example the cursor is positioned blinking at the beginning of the line "CCCCCCCCC"
I need a code that copies from the cursor line to the end. in this case the copy would be:
"CCCCCCCCC
DDDDDDDDD
FFFFFFFFFFF
GGGGGGGG "
"CCCCCCCCC
DDDDDDDDD
FFFFFFFFFFF
GGGGGGGG "
the first code worked well, the others were not successful, in any case it was resolved, thanks.
All code fragments in this topic select and copy text starting from the blinking caret and to the end of the document, as you asked.
If you have problems with the code I posted, please let me know what's wrong exactly.
