Is there a simple way to adjust the default table setting for RichViewActions. I see some default settings but not on all.
I would like to do clSilver for border color, and only a 1 width cell border. I can do it after the creation but it would be nice to do it when the table is made.
Simple way to set the default table settings for RichViewActions
Re: Simple way to set the default table settings for RichViewActions
Change properties of TrvActionInsertTable
Thanks found a way appreciate it.
