UTF8
standay
UTF8
Post by standay »
What is the simplest way to load a file with specific encoding? On most editor components I use I can do it this way:
memo.Lines.LoadFromFile('test.txt',TEncoding.UTF8);
What I did with the SRichView was this:
  ms := TStringStream.Create('', TEncoding.UTF8);
  ms.LoadFromFile(FileName);
  ms.Position := 0;
  SRichViewEdit1.ActiveEditor.InsertText( ms.DataString );
  ms.Free;
That works but is there some easier way I'm missing?
Also, is there a way to make opening and saving text files as UTF8 default?
Thanks!
Re: UTF8
The simplest way is to specify 65001 in the CodePage parameter of the text loading methods.
Loading:
  RichViewEdit1.Clear;
  RichViewEdit1.LoadText(FileName, 0, 0, False, 65001);
  RichViewEdit1.Format;
Inserting at the caret position:
  RichViewEdit1.InsertTextFromFileUTF8(FileName);
or
  RichViewEdit1.InsertTextFromFile(FileName, 65001);
standay
Re: UTF8
Post by standay »
Thanks Sergey, I'll give this a try later today.
Yes, all these worked, thanks. Also used:
SRichViewEdit1.ActiveEditor.InsertTextFromFile(FileName, TEncoding.UTF8.CodePage);
Which works too.
