XHtml to stream export
wvd_vegt
Post by wvd_vegt »
Is there support for exporting xhtml into a stream so I can stream it directly into an embeddedWB from EuroMind without saving to disc first?
rv.SaveHTMLToStreamEx
wvd_vegt
Post by wvd_vegt »
For people interested the following code works like charm:
procedure T_TaakEditor.DoPreview(rve: TRichViewEdit);
  ms                 : TMemoryStream;
  ms := TMemoryStream.Create;
  rve.SaveHTMLToStreamEx(ms,
    ChangeFileExt(Application.ExeName, '.xhtml'),
    'A Title', '', '', '', '',
    [rvsoUTF8, rvsoXHTML]);
  ms.Seek(0, soFromBeginning);
  emBeddedWB1.LoadFromStream(ms);
wvd_vegt
Post by wvd_vegt »
When i stream from TRichViewEdit into EmebbedWb the images are saved on disk. Hyperlinks are present in the generated xhtml but lack path & file:// protocol.
Is there a way to correct this?
TRichView does not save hyperlinks in HTML itself. It's done in OnWriteHyperlink event. Modify code in this event to add protocol prefixes when necessary
wvd_vegt
Post by wvd_vegt »
This event isn't fired during the SaveHTMLToStreamEx call. Any suggestions?
Sorry, it's not possible.
If this event is not fired, all hyperlink would be written as a plain text (hyperlink target is provided by this event, or by obsolete OnURLNeeded)
wvd_vegt
Post by wvd_vegt »
Perhaps i need to clarify, i dropped an image from the file system into a TRichViewEdit and call the streaming function.
The output is:
<img alt="" hspace="1" vspace="1" src="Pim.xhtml13.jpg" />
I did some digging and found that OnHtmlSaveImage is called but for it to work i need to manually save the Image but can't get the Filename from the ItemNo supplied.
I Also found that setting doDefault to true saves the image to disc (as i want to) but also resets the filename written into the html generated.
wvd_vegt
Preview content in an EmbeddedWB including disc based Images
Post by wvd_vegt »
Finnaly figured it out. The trick lies in the OnSaveImage Event but needs to duplicate some code from TCustomRVData.DoSavePicture.
Only minor flaw is that the OverrideFileNames parameter isn't available so I had to set it to false (but as the calling program passes it in, it's also known inside the eventhandler).
Result is an image save to disc and a correct file:/// type url in the generated xhtml.
The OnSaveImage2 eventhandler:
procedure TXHtmlEditFrame.RichViewEdit1SaveImage2(Sender: TCustomRichView;
  Graphic: TGraphic; SaveFormat: TRVSaveFormat; const Path,
  ImagePrefix: string; var ImageSaveNo: Integer; var Location: string;
  var DoDefault: Boolean);
  ext               : string;
  fn                : string;
  if SaveFormat = rvsfHTML then
      ext := '.jpg';
      if RV_IsHTMLGraphicFormat(Graphic) then
        ext := '.' + GraphicExtension(TGraphicClass(Graphic.ClassType));
    end
    ext := '.bmp';
  fn := Sender.RVData.GetNextFileName(ImagePrefix, Path, Ext, ImageSaveNo, false); //no OverrideFileNames
  if (SaveFormat = rvsfHTML) and
    ((Graphic is TJpegImage) or RV_IsHTMLGraphicFormat(Graphic)) then
    Graphic.SaveToFile(fn);
//Sample: src="file:///C:/Bureaublad/Joe_s_Garage.gif"
  Location := 'File:///' + StringReplace(fn, '\', '//', [rfReplaceAll]);
  DoDefault := False;
And the calling routine that previews TRichViewEdit content in an EmbeddedWB including disc based images:
  ms                : TMemoryStream;
  rve.RVData.Flags := rve.RVData.Flags + [rvflRoot];
    ExtractFilePath(Application.ExeName),
  Preview.LoadFromStream(ms);
That's right, but you initially asked about hyperlinks, not images :)
wvd_vegt
Post by wvd_vegt »
My excuses for mixing them up again. I tend to treat everything with a url as a hyperlink.
But is it possible to change the routines a bit so you can save the image more easily by calling the code already present in TRichView? I find copying peices code to archieve a minor enhancement awkward as the copied piece may change for next releases of a library like TRIchView.
procedure TForm3.RichViewEdit1SaveImage2(Sender: TCustomRichView;
  ImagePrefix: String; var ImageSaveNo: Integer; var Location: String;
  Location := Sender.RVData.SavePicture(SaveFormat, ImagePrefix, Path, ImageSaveNo, True,
    clWhite, Graphic);
  Location := 'file://' + StringReplace(Path+Location, '\', '/', [rfReplaceAll]);
  DoDefault := False;
Corrected: '\' should be changed to '/', not to '//'
Last edited by Sergey Tkachenko on Fri Sep 23, 2005 9:23 am, edited 1 time in total.
wvd_vegt
Post by wvd_vegt »
Thanks, works like charm (and is much shorter).
I have corrected the example
