How can I get SelStart?
Ilya Shalnov
Post by Ilya Shalnov »
I try to do that this way
uses
... RVLinear;
function SelStart(RVE:TRichViewEdit):integer;
SelStart:integer;
SelLength:integer;
int:integer;
RVGetSelection(RVE,SelStart,SelLength,int);
Result:=SelStart;
When it is done with the first line, it works fine. When I go to the second line or to any other line the function returns some very big number.
Re: How can I get SelStart?
The last parameter of RVGetSelection is a number of characters per a line break.
You pass an uninitialized value to the last parameter, so the results RVGetSelection become random for the second and further lines.
Normally, either 1 or 2 are used for this parameter. The default of RVGetSelection is 2.
I recommend to use the default value:
RVGetSelection(RVE,SelStart,SelLength)
Ilya Shalnov
Thank you, it works now!
