Top 2 Best Sewing Machines With Overlock Function
jameswalker
Post by jameswalker »
An ideal sewing machine for alterations should come with an overlock function. With this function, you can perform many tasks in sewing. For example, it is capable of sewing over the edge of two pieces of fabric; hence, it can be useful for hemming and seaming. You need to feed the fabrics through the overlock function, and it will cut the edges of the cloth.
Machines that have this function are referred to as sergers or overlock machines. You can learn more about them atImage CraftsSelection.com Reviews of Best Products. CraftsSelection is an amazing website that provides you with comprehensive product reviews, buying guides and helpful comparisons of sewing machines, embroidery machines, vinyl cutters, heat press machines, and craft machines.
The following are the two best sewing machines with overlock functions we selected after testing them out.
Singer S0100 Serger Overlock Machine
Singer S0100 is a 2, 3 and 4-thread capacity overlock machine with a speed of up to 1,300 SPM, making it one of the quickest options around. It is an overlock sewing machine that comes with an extended free arm and a lower looper LED light.
With a speed of 1300 SPM, this sewing machine offers an incredible boost to your efficiency by making you complete sewing work in less time. It is powered by corded electricity and weighs just 7.3 kg. The Singer S0100 is an ideal overlock sewing machine for those who are budget-conscious because it comes at a reasonable price.
✩✩✩ See This Page: https://ko-fi.com/craftsselection Image
Brother 1034D Overlock Machine
If you are looking for an overlock sewing machine for larger projects, Brother 1034D should be your priority. It is made of polished metal and plastic materials, so it is very lightweight and durable. This corded electric-powered serger weighs slightly above 8 pounds, making it easy for transportation and storage. It is a reliable 3 and 4-thread machine that offers up to 1,300 stitches per minute of speed.
It comes with a number of advanced features and accessories, such as an under-looper threader, a removable trim trap, and three feet. The three feet included here are the standard, gathering, and blind stitch options.
Moreover, it is made of a blend of plastic and metal material, which add to its durability and lightweight feel. This compact sewing machine can fit perfectly into your sewing space. You can look up CraftsSelection Top Craft and Sewing Product Guides Imageto learn more about this product and other helpful insights.
Finding Your Ideal Overlocking Sewing Machine
Aside from the regular factors like stitch length and width, number of thread capabilities, and price of the machine, you should consider some other things when deciding which overlock sewing machine you want. You may use our sewing machine comparisons on CraftsSelection website to compare similar models that meet your requirements.
Most overlock machines operate similarly, however, some offer extras you may not find in others, and those could save you money or be the deciding factor. You don’t have to be brand-specific when searching because there are certain brands that offer overlock sewing machines that can compete with the more popular brands.
Re: Question about RVMedia
Sorry no.
When you specify RVCamera.DesktopMode := rvdmWindow and assign RVCamera.DesktopWindowHandle, RVMedia streams video from the screen area that contain this window. If this window is covered by other windows, these other windows will be shown.
