File Wav cannot playing
Hi, I try to play wav file by rvmicrophone and I had already set rvmicrophone.WavFileName, rvmicrophone.sourcetype = rvsstWav and rvmicrophone.active = true but the file does not play. What should I do?
Re: File Wav cannot playing
And can't found any data from event ReadWavFile
Probably, this file is compressed. Currently, TRVCamMicrophone supports only uncompressed wav files.
How to check if wav files are uncompressed or not?
or do you have any example wav files that will definitely work?
Please send me this file to email richviewgmailcom
