How to check if RVE contain picture?
CCY
Post by CCY »
How can I check when an RVE content has picture in it?
shmp
Post by shmp »
var count, itemstyle;
for count := 0 to rve.ItemCount - 1 do begin
itemstyle := rve.GetItemStyle(count);
if itemstyle = rvsTable then begin
{you have to iterate through each cells}
end else if (itemstyle = rvsPicture) or (itemstyle = rvsHotPicture) then
{there is a picture!}
Hope this help.
Yes, it's possible to do it with recursive procedure.
Another way is using (undocumented) RVData.EnumItems method. This method calls the specified procedure for each item in TRichView.
// This procedure will be called for each RichView item
procedure TForm3.EnumItemsProc(RVData: TCustomRVData; ItemNo: Integer;
  var UserData1: Integer; const UserData2: String;
  var ContinueEnum: Boolean);
  if (RVData.GetItemStyle(ItemNo)=rvsPicture) or
     (RVData.GetItemStyle(ItemNo)=rvsHotPicture) then begin
    UserData1 := 1;
    ContinueEnum := False;
    end
    ContinueEnum := True;
procedure TForm3.Button1Click(Sender: TObject);
var HasPictures: Integer;
  HasPictures := 0;
  RichViewEdit1.RVData.EnumItems(EnumItemsProc, HasPictures, '');
  if HasPictures<>0 then
    Caption := 'YES'
    Caption := 'NO';
The procedure above checks only picture items.
Pictures can also appear:
- as document background
- as table background
- as table cell background
- as paragraph markers (pictures-bullets)
- "hotspots" and "bullets" (pictures from image lists)
I do not know if you need to detect them all.
