I just installed RichView 20.3 trial for Delphi 10.3 Rio. When I opened my project afterwards, Delphi reported the non-existing property "PixelPerInch" for "rvActionsImageCollection1" and "rvActionsVirtualImageLists" - the data modules from ..\RichViewActions\Source
RV 20.3: Property "PixelPerInch" doesn't exist
Re: RV 20.3: Property "PixelPerInch" doesn't exist
Thank you for informing me.
This datamodule was accidentally saved in a newer version of Delphi that added "PixelsPerInch" property in DFM. This problem is in 3 datamodules in RichViewActions.
I'll remove fix in the next update.
Here are the fixed DFM files:
https://www.trichview.com/support/files/temp/rvadfm.zip
Replace the files in <TRichView Dir>\RichViewActions\Source\
I fixed this problem in TRichView setup v20.3.1.
