Hello!
Suppose that, at the start of the server, I want to load a set of defined rooms (that are implemented via groups).
How can I do this? Can I do this??
I haven't found anything that would suggest I can do this in the examples, but it would be useful.
Any pointers, please? I am using the latest trial.
Thanks!
Preloading groups in the server
Re: Preloading groups in the server
I am sorry for overlooking this question. And sorry, this feature is not supported yet.
If you are interested, I can add methods to TRVMediaServer for group management. However, they will only return info about groups and allow to create them and add/remove users. You will need to store group data yourself.
Hi!
That would be perfectly acceptable
All I need is a way to make sure they're created even if there are no users in.
Thanks!
Thanks!
