Accelerate ApplyStyleConversion
edgarharris155
Post by edgarharris155 »
Hello
I have rtf document with a table, opened in TRichViewEdit.
Lines insertion into the table works fast. Then I insert text into cells with InsertText, or use ApplyStyleConversion on cells, and it takes about 20 seconds to fill the table.
Table size 8 columns * 85 lines, 10 symbols in a cell.
TRichView 12.6.
Can I speed it up somehow?
Thank you!
Re: Accelerate ApplyStyleConversion
This is quite an old version of TRichView.
Did you try a newer version?
