After updating to TRichView v21.1
candsoft
Post by candsoft »
Hello :D
CompileError occurs in RVMathitem.pas ( Not enough actual parameters )
Can you check it?
Thanks!!
standay
Re: After updating to TRichView v21.1
Post by standay »
Candsoft, I had some misc compile errors too with initial install of 21.1. I think I closed Delphi and restarted and everything seemed to settle down. Not sure what the errors were now but things are OK. Using Delphi 10.3. Just FYI. Stan
I confirm that RVMathItem.pas was not updated in the Setup.
I'll upload a fixed version later today.
As a quick fix, you can add False as the last parameter on the lines that generate the error.
standay
Post by standay »
Thanks Sergey
candsoft
Post by candsoft »
It is compiled by following your advice
Thanks :D
A fixed setup has been uploaded.
(but if you already made the changes, you do not need to reinstall)
