Hi
Do you remember Quick Report summary band ? Well, I need something like that. I want to print the footer just in the end of the text instead to print in the bottom page.
Is it possible with TRichView ?
Summary
At the end of each page?
There is no an elegant solution for this.
Possible solution:
1) Format document for printing (RVPrint.FormatPages)
2) Save each page in new document (RVPrint.SavePageAsRVF - undocumented method). It may be done page by page, not necessary the same pages at once.
3) Prepare footer in another RichView
4) Using the code shown in http://www.trichview.com/forums/viewtopic.php?t=87 , print many documents in one printing job.
In this example
rvFullDoc - TRichView (or editor) containing the whole document
rvPage - hidden TRichView, used to store one page during printing
rvFooter - TRichView (or editor) containing footer
RVPrint1 - TRVPrint used to format the whole document (repaginate it)
RVPrint2 - TRVPrint used for actual printing
Possible solution:
Printer.BeginDoc;
RVPrint1.AssignSource(rvFullDoc);
RVPrint1.FormatPages(rvdoAll);
for i := 1 to RVPrint1.PageCount do
if i>1 then
Printer.NewPage;
RVPrint1.SavePageAsRVF(Stream, i);
Stream.Position := 0;
rvPage.LoadRVFFromStream(Stream);
Stream.Free;
RVPrint2.AssignSource(rvPage);
RVPrint2.StartAt := 0;
RVPrint2.FormatPages(rvdoAll);
RVPrint2.ContinuousPrint;
RVPrint2.StartAt := RVPrint2.EndAt;
RVPrint2.AssignSource(rvFooter);
Printer.EndDoc;
