[Example] Loading UTF-8 files
Very simple example - how to load Unicode UTF-8 file:
procedure LoadUTF8(rv: TCustomRichView; const FileName: String;
  StyleNo, ParaNo: Integer);
var Stream: TFileStream;
    s: TRVRawByteString;
    ws: TRVUnicodeString;
  Stream := TFileStream.Create(FileName, fmOpenRead);
  SetLength(s, Stream.Size);
  Stream.ReadBuffer(PRVAnsiChar(s)^, Stream.Size);
  Stream.Free;
  rv.Clear;
  ws := UTF8Decode(s);
  rv.AddTextNLW(ws, StyleNo, ParaNo, ParaNo, False);
Call:
LoadUTF8(RichViewEdit1, 'test.txt', 0, 0);
RichViewEdit1.Format;
(If the StyleNo-th style has Unicode property = True, the file will be
loaded as it is. If not, it will be converted to ANSI text)
(2008-Dec-9: updated for compatibility with TRichView 11 and Delphi 2009)
