saving bullets to html with spcecial imagename
dport
Post by dport »
When saving bullets to an html file, is it possible to save them under a name we want instead of in order? For example, if we give the file name to the first parameter (aname) when adding a bullet, can we have it save with that file name when saving?
For example
rv.AddBullet ('xx.jpg',1,ImageList1,rvsnormal);
Can we make the bullet I added appear as <img src=xx.jpg> in the html output?
Re: saving bullets to html with spcecial imagename
It must be the default behavior: for all bullet items with the same ImageList and ImageIndex, a single image file is saved.
It may be different only if bullets are displayed on different background color (because if bullets are saved as non-transparent images, a background color is drawn in images)
If you want to modify image saving, use OnHTMLSaveImage event.
