Problem with image sizes
antarey
Post by antarey »
Good afternoon.
I use TRichView FMX 22.2 and C++Builder 12.
I insert pictures *.png/*.jpg/*.webp
I insert the image like this:
TRVGraphicFM* Graphic;
		OpenDialog->Filter = "Images|*.bmp;*.jpg;*.jpeg;*.png;*.gif;*.tif;*.tiff;*.ico;*.webp";
		if (OpenDialog->Execute()) {
			Graphic = RVGraphicHandler->LoadFromFile(OpenDialog->FileName);
			if (Graphic != NULL) {
				ActiveEditor->InsertPicture("", Graphic, rvvaAbsMiddle);
I am exporting to html
rve->SaveHTMLToStream(HtmlText, FolderToExport + "\\", rvhtmlspMiddle);
Images are saved separately from HTML.
File sizes increase greatly. The size of png/jpg increases +- 2 times. But webp from 84k increased to 700k.
The image sizes were not changed.
I re-read the certificate and nothing is written about quality.
How to save images in original quality as is?
Thanks in advance for your help
Re: Problem with image sizes
TRichView for FireMonkey saves images with default parameters.
For WebP, when parameters are not specified, Skia4Delphi chooses maximum image quality, so images are saved lossless (or almost lossless), resulting large files.
In the next update, I'll add a new global variable RVDefaultImageSavingQuality in fmxRVGraphicsFM.pas:
  // encode quality 0..100
  RVDefaultImageSavingQuality: Integer = 100;
It will be used to define saving quality for all formats that use lossy compression.
Probably, in future, I'll add SavingQuality property to image objects in TRichView documents.
