I want the user cannot write more than 12 lines
armagnac
Post by armagnac »
As I say in the title, I want to limit the number of lines writed by the user in a TRichViewEdit.
Maybe there are different ways :
- disable KeyPress if line count > 12
- unable the rve to scroll is user want to begin a 13th line
- other idea
Re: I want the user cannot write more than 12 lines
There is no built-in line count limitation.
You can process OnChange event.
In this event, check line count:
function IsParaCountOk(rv: TCustomRichView; MaxCount: Integer): Boolean;
  Count: Integer;
  Result := False;
  Count := 0;
  for i := 0 ro rv.ItemCount - 1 do
    if rv.IsFromNewLine[i] then
      inc(Count);
      if Count > MaxCount then
   Result := True;
If not ok, call Undo.
