skia4delphi and svg
standay
skia4delphi and svg
Post by standay »
I installed skia4delphi and was able to get webp files to insert correctly in a regular richview edit. However, while I can insert svg files just fine, when I save the rvf file and reopen it, all I get is an image with an X in it and the inserted svg file no longer shows. Webp files are working as expected.
Is there some special trick to getting the inserted svg to work? I'm still using rve 21.7.3 so that may be the issue but I wanted to see if anyone has been able to do this.
Re: skia4delphi and svg
This problem is solved in TRichView 22 (you need to include RVSkia unit in your project).
There is a problem with loading SVG from stream using TSkSvgGraphic, because there is no access to this class (it is declared in the private section).
RVSkia unit implements a workaround.
standay
Post by standay »
OK, that's what I thought might be the case.
Thanks Sergey
