I have a problem with setting the TRVMathItemInfo.TextColor property. When the formula is created (a new one is added), this property works fine. But when the formula already exists and I try to change the TextColor, nothing happens. The same problem occurs with the visual formula editor TfrmRVMathEditor, if I change the TextColor through this form.
Can you tell me how to fix this problem?
TRVMathItemInfo.TextColor problem on existing objects
Re: TRVMathItemInfo.TextColor problem on existing objects
I confirm the problem.
A new color is assigned to the equation item, but is not applied until you make changes that may affect the equation size (such as changing an equation text or a font size).
I fixed it, it will be included in the next update.
If you need, I can send a changed unit to you by email.
Thank you Sergey, by email would be great.
