How to use Redo after TRVUndoList.AddInfo?
Vitalii
Post by Vitalii »
Hi, I have read other forum threads regarding "Custom Undo" operations, but I did not find an answer.
Based on this topic, I implemented a custom Undo class, and it works fine:
class procedure TRVUndoModifyMathObject.AddUndo(RVData: TRichViewRVData;
  ItemInfo: TRVMathObjectItemInfo);
  Edit: TCustomRichViewEdit;
  UndoList: TRVUndoList;
  UndoItem: TRVUndoModifyMathObject;
  if RVData = nil then Exit;
  Edit := TCustomRichViewEdit(RVData.GetAbsoluteRootData.GetParentControl);
  UndoList := TRVEditRVData(RVData).GetUndoList;
  if Assigned(UndoList) then
      UndoItem := TRVUndoModifyMathObject.Create;
      UndoItem.Action := rvuMisc;
      UndoItem.FInputExpression := ItemInfo.Expression;
      UndoItem.FOutputExpression := ItemInfo.OutputExpression;
      UndoItem.FOutputFormat := ItemInfo.OutputFormat;
      UndoItem.FTitle := ItemInfo.TextAlias;
      UndoItem.FItemNo := RVData.GetItemNo(ItemInfo);
      UndoList.AddInfo(UndoItem, Edit);
The main code that applies the changes:
  if AEdit.CanChange then
      AEdit.BeginUndoCustomGroup('Modify Math Object');
      TRVUndoModifyMathObject.AddUndo(AEdit.RVData, ItemInfo);
      ItemInfo.Expression := MemoInput.Lines.Text;
      ItemInfo.OutputExpression := EditOutput.Text;
      ItemInfo.OutputFormat := ComboBoxOutputFormat.Text;
      ItemInfo.TextAlias := EditTitle.Text;
      AEdit.Change;
      AEdit.RefreshAll;
Unfortunately, Redo does not respond... What should I change/add to make the Redo stack work properly?
Re: How to use Redo after TRVUndoList.AddInfo?
Is this main code inside TRVUndoModifyMathObject.Undo?
Can I see the full TRVUndoModifyMathObject implementation?
PS. If you need to modify integer and string properties of an item, there is an alternative solution. You do not need to implement custom undo object. Instead, you can implement extra item properties. Then you can use methods for setting these properties, and it can be undone/redone.
See https://www.trichview.com/forums/viewtopic.php?p=42899
Vitalii
Post by Vitalii »
Yes, implementation of the TRVUndoModifyMathObject.Undo is here:
procedure TRVUndoModifyMathObject.Undo(RVData: TRichViewRVData);
  ItemInfo: TRVMathObjectItemInfo;
  if FItemNo > -1 then
      ItemInfo := TRVMathObjectItemInfo(RVData.GetItem(FItemNo));
      if Assigned(ItemInfo) then
          ItemInfo.Expression := FInputExpression;
          ItemInfo.OutputExpression := FOutputExpression;
          ItemInfo.OutputFormat := FOutputFormat;
          ItemInfo.TextAlias := FTitle;
As I said, this Undo method works correctly. Other methods are trivial:
constructor TRVUndoModifyMathObject.Create;
  inherited;
  FInputExpression := '';
  FOutputExpression := '';
  FOutputFormat := '';
  FTitle := '';
  FItemNo := -1;
function TRVUndoModifyMathObject.RequiresFormat: Boolean;
  Result := False;
The "main code" is called through an external editor window (UI). This code is not part of the class TRVUndoModifyMathObject. My logic here is: before making changes, we create an Undo-object, make changes, and change/refresh editor. But I don't know if this Undo-object still works in Redo operations?
UndoItem.Undo must
1) save the current object state in a new undo item (when undoing, this new undo item will be inserted in the redo list; otherwise, in the undo list)
2) make changes in the object.
Let's see how a very simple undo item is implemented: TRVUndoChangeVAlignInfo, it changes VAlign property of an item.
procedure TRVUndoChangeVAlignInfo.Undo(RVData: TRichViewRVData);
  TRVEditRVData(RVData).Do_ChangeVAlign(ItemNo, VAlign);
where
procedure TRVEditRVData.Do_ChangeVAlign(ItemNo: Integer; VAlign: TRVVAlign);
  List: TRVUndoList;
  ui:   TRVUndoChangeVAlignInfo;
  item: TCustomRVItemInfo;
  item := GetItem(ItemNo);
  if (item as TRVRectItemInfo).VAlign = VAlign then
  // storing the old state in the new undo item
  List := GetUndoList;
  if List <> nil then
    ui := TRVUndoChangeVAlignInfo.Create;
    ui.Action := rvuChangeText;
    ui.ItemNo := ItemNo;
    ui.VAlign := TRVRectItemInfo(item).VAlign;
    List.AddInfo(ui, TCustomRichViewEdit(OwnerRichView));
  // making changes
  TRVRectItemInfo(item).VAlign := VAlign;
Vitalii
Post by Vitalii »
Yep, I need to add "AddUndo" to the Undo method. Thank you, Sergey)
