How to make a fontstyle format brush like in MS Word?
uniandy
Post by uniandy »
Hi, Sergey,
How to make a fontstyle format brush in Richviewedit by using a button, the functionality is just like in Microsoft Word?
I have no any idea of implementing this in my test, can you please help me out?
Andy :lol:
RichViewActions ( http://www.trichview.com/resources/actions/ ) implements something like this. But not exactly like in MS Word (In MS Word, this is a combo button, displaying the last applying color, and it allows to reapply the last color on single click; this is not impemented yet)
uniandy
Post by uniandy »
Hi, Sergey,
Thank you, but I mean, how to get all the fontstyle for the cursor position in the text, the fontstyle is not limited to color, but all the style like color, fontname, font size etc.
When I get the style and saved it to an object like fs:Tfontstyle, then I can apply this fs to any text selected and change the text selection style exactly like the fontstyle I want.
can there be some methods to do this?
You can do it using ApplyStyleConversion method.
This method calls OnStyleConversion event for all text item in the selection, allowing to change font style properties.
See the demo in Demos\Editors\Editor 2\
uniandy
Can you help me out?
Post by uniandy »
HI, Sergey-
After some tries I still cannot find a way to make fontstyle format brush like in MS Word?
How can I get all the font style which i selected and how to apply them to another text selection?
Can you possibily indicate me with code samples?
Thank you very much!
Andy
Ok, let we have RichViewEdit1: TRichViewEdit, linked to RVStyle1: TRVStyle.
TextStyle: TFontInfo; // form's variable
Reading current text format:
TextStyle.Free;
TextStyle.Assign(RVStyle.TextStyles[RichViewEdit1.CurTextStyleNo]);
Applying to the selection:
var StyleNo: Integer;
if TextStyle<>nil then begin
  StyleNo := RVStyle1.TextStyles.FindSuchStyle(0, RVAllFontInfoProperties);
  if StyleNo<0 then begin
    RVStyle1.TextStyles.Add;
    StyleNo := RVStyle1.TextStyles.Count-1;
    RVStyle1.TextStyles[StyleNo].Assign(TextStyle);
    RVStyle1.TextStyles[StyleNo].Standard := False;
  RichViewEdit1.ApplyTextStyle(StyleNo);
On destroying the form:
TextStyle.Free;
Well, there is a simpler solution.
StyleNo: Integer; // form's variable
On form's creation:
StyleNo := -1;
Reading the current text format:
StyleNo := RichViewEdit1.CurTextStyleNo;
if StyleNo>=0 then
The only problem with this solution is: the stored value of StyleNo becomes invalid after creating a new document (File | New) or loading another document (File | Open), so you should reset it to -1.
uniandy
Thank you, Sergey!
Post by uniandy »
Hi, Sergey,
I have done with the font format brush, thank you for your kind hints and help.
Andy
