Problem in Table
Tarun
Problem in Table
Post by Tarun »
I am facing problem in table of the Rich view.
Create a table with suppose 3 rows and 3 columns in richview, put the editing
off of first row and then select any full column and then press bold/underline
any button the text of the column will be changed accordingly but it doesn't revert back even on pressing bold button.
Please provide me the solution
Regards:
Tarun
Do you use RichViewActions?
If yes, this problem must be fixed in new version of RichViewActions.
Tarun
Problem in Rich view table
Post by Tarun »
I am using 1.4 version of RV
Is yours new Rich View version solve the copy/paste problem that when
1. we copy the bulleted text from Excel/word and paste into Richview
table then bullets becomes numbers.
2. Allignment problem:
Allignment is not properly working on pasting data from word/Excel
to RV table
3. Style problem:
When we are pasting data from word/Excel to RV table background
colour is not copied
You use very old version of TRichView, please upgrade.
The problem with bold and multicell selection is not actually TRichViewEdit problem, but a problem of RichViewActions (font buttons did not update their state for multicell selection, they were always unchecked, so clicking them always applied font attributes and never removed them). This problem is fixed in new version of RichViewActions.
I believe many (or all) of the listed problems are fixed too.
Tarun
Post by Tarun »
Thanks for updating..
Regards:
Tarun
