Set tabs by buttonClick
Question to Pieters ruler:
Who can tell me how I can set 2 tabs by buttonClick. One right tab at 4 cm and one left tab at 12cm ?
Jürgen
Jürgen
Ok. Assuming that you do not use RichViewActions... All editing operations on paragraph attributes, including tabs, must be implemented using ApplyParaStyleConversion procedure + OnParaStyleConversion event.
How to add this command to the demo in Demos\Delphi\Editors\Editor 2\:
Open Unit1.pas.
Find declaration of PARA_* constants.
Add a new constant, with unique value among them:
Place a button, call in its OnClick:
Add RVFuncs in uses.
Add the following function, converting mm to pixels:
Find TForm1.rveParaStyleConversion. Add
to its vars.
In its case operator, add:
Open Unit1.pas.
PARA_TAB = 5;
rve.ApplyParaStyleConversion(PARA_TAB);
function MMToPixels(mm: Integer): Integer;
var ppi: Integer;
ppi := RichViewPixelsPerInch;
if ppi=0 then
ppi := Screen.PixelsPerInch;
Result := Round ( mm * 5 * ppi / 127 );
Tabs: TRVTabInfos;
PARA_TAB:
Tabs := TRVTabInfos.Create(nil);
with Tabs.Add do begin
Position := MMToPixels(40);
Align := rvtaRight;
Position := MMToPixels(130);
Align := rvtaLeft;
ParaInfo.Tabs.AddFrom(Tabs);
Tabs.Free;
Funny, just mailed a similar answer. Is there any specific reason you're using the way of creating TRVTabInfos and assigning it to ParaInfo.Tabs instead of using ParaInfo.Tabs directly?
ParaInfo.Tabs.Clear;
with ParaInfo.Tabs.Add do begin
Align := rvtaLeft;
// etc
Hello Sergey, hello Pieter,
thanks for your answers.
It has a simple reason why I want to set a tab stop about delphi-code (= buttonClick).
People write a text (in rveMemo). My program has the option to set a text as '------- Ende des Berichts ----' 2 lines under the last line of user-text.
First I attach the line with 35 spaces before Text:
<35 spaces>+'------- Ende des Berichts ----'.
After writing much (many) memos I saw that the attached text doesn't begin at the same position (it depends from the the attributes of last line before I attached the 'Ende des Berichts'-line. Spaces with font.size 20 are more broadly as spaces with font.size 10.
I thought that it may be a simple way to start the 'Ende..'- text always at the same position about tab-stops.
If there is no (simple ?) solution I want to go following way:
I save the last text-attributes and create a new font.size, font.name etc for the new line and set the line as before (<35 spaces>+'------- Ende des Berichts ----').
After that I attach the old attributes.
Independently of it I want to know how I can set a tab-stop (left, right, middle) to a wanted position of a (wanted) line.
I hope you have a simple solution.
Jürgen
Jürgen
Pieter, your code clears all existing tabs and then adds new tabs. My code adds new tabs in addition to the existing tabs.
Without clearing, you should search if some tab exists at the given position (using ParaInfo.Tabs.Find), and, if exists, update its properties instead of adding a new tab. Using a local tab collection + AddFrom is a bit simpler.
Well, in the original post it was not specified clearly if the existing tabs should be kept or not.
j&b, so, as I understand, you need to create a paragraph style with the given tab stops to add some text lines formatted with this paragraph style.
How to add line of the given paragraph style to the end of document
1) As an editing operation, using current text style
2) Not as en editing operation. Works both for TRichView and TRichViewEdit.
I hope this is what you asked for.
{ This function returns index of paragraph style with the
specified collection of tabs. If such paragraph style does not
exist, this function adds it.
(this function uses MMToPixels from the previous example)
function GetParaStyleWithTabs(rvs: TRVStyle): Integer;
var ParaInfo: TParaInfo;
ParaInfo := TParaInfo.Create(nil);
Align := rvtaRight;
Align := rvtaLeft;
Result := rvs.ParaStyles.FindSuchStyle(0,ParaInfo,RVAllParaInfoProperties);
if Result=-1 then begin
rvs.ParaStyles.Add;
Result := rvs.ParaStyles.Count-1;
rvs.ParaStyles[Result].Assign(ParaInfo);
rvs.ParaStyles[Result].Standard := False;
ParaInfo.Free;
var ItemNo, Offs: Integer;
ItemNo := rve.ItemCount-1;
Offs := rve.GetOffsAfterItem(ItemNo);
rve.SetSelectionBounds(ItemNo, Offs, ItemNo, Offs);
rve.InsertText(#13);
rve.ApplyParaStyle(GetParaStyleWithTabs(rve.Style));
rve.InsertText(#9'------- Ende des Berichts ----');
var i, ParaNo, StyleNo: Integer;
// searching for the last text item, using its text style
StyleNo := 0;
for i := rve.ItemCount-1 downto 0 do
if rve.GetItemStyle(i)>=0 then begin
StyleNo := rve.GetItemStyle(i);
break;
ParaNo := GetParaStyleWithTabs(rve.Style);
// you cannot use AddNL for strings with tab characters
rve.AddTextNLA((#9'------- Ende des Berichts ----', StyleNo, ParaNo, ParaNo);
rve.Format;
rve.ClearUndo; // if called for editor
Thanks for your help !
I have solved my problems with your help.
I have prefered Sergeys solution because I only have to add some lines (look at "<-----")
My example has one problem:
Today I don't know how many tab_1 (up to tab_n) I need in some days.
How can I solve this problem and how can I optize my code (look at TForm1.TabSetzenClick and
to the part "PARA_TAB: //<-------ADD---------------" of TForm1.memoParaStyleConversion(...)
Jürgen
Jürgen
procedure TForm1.TabSetzenClick(Sender: TObject); //<--------------
tab_clear:=true;
tab_1:= 5; tab_1_align:= 1; //1: left, 2: center, 3: right
tab_2:= 12; tab_2_align:= 2;
memo.ApplyParaStyleConversion(PARA_TAB);
uses ..., RVFuncs;
1.
private
//rv
..., tab_clear: Boolean;
..., tab_1, tab_2, tab_1_align, tab_2_align: Integer;
//rv-Ende
2.
{$R *.dfm}
const
//rv
rv_MAKEBOLD = 1;
// Parameters for ApplyParaStyleConversion
PARA_ALIGNMENT = 1;
PARA_INDENTINC = 2;
PARA_INDENTDEC = 3;
PARA_COLOR = 4;
PARA_TAB = 5; <-------------------
//rv-Ende
3.
procedure TForm1.memoParaStyleConversion(Sender: ....);
function MMToPixels(mm: Integer): Integer; //<------------
var ppi: Integer;
if ppi=0 then ppi := Screen.PixelsPerInch;
end; //<--------------
Tabs: TRVTabInfos; //<--------------
ParaInfo.Assign(rvs.ParaStyles[StyleNo]);
case UserData of
PARA_ALIGNMENT: ParaInfo.Alignment := GetAlignmentFromUI;
PARA_INDENTINC:
ParaInfo.LeftIndent := ParaInfo.LeftIndent+20;
if ParaInfo.LeftIndent>200 then ParaInfo.LeftIndent := 200;
PARA_INDENTDEC:
ParaInfo.LeftIndent := ParaInfo.LeftIndent-20;
if ParaInfo.LeftIndent<0 then ParaInfo.LeftIndent := 0;
PARA_TAB: //<---------------------------------------
if tab_clear=true then begin ParaInfo.Tabs.clear; tab_clear:= false; end;
if tab_1>0 then begin
Position := MMToPixels(tab_1);
if tab_1_align=1 then Align := rvtaLeft
else if tab_1_align=2 then Align := rvtaCenter
else if tab_1_align=3 then Align := rvtaRight;
if tab_2>0 then begin
Position := MMToPixels(tab_2);
if tab_2_align=1 then Align := rvtaLeft
else if tab_2_align=2 then Align := rvtaCenter
else if tab_2_align=3 then Align := rvtaRight;
Tabs.Free;
end; //<---------------------------------------
PARA_COLOR: ParaInfo.Background.Color := cd.Color;
end; //o case
NewStyleNo := rvs.ParaStyles.FindSuchStyle(StyleNo,ParaInfo,RVAllParaInfoProperties);
if NewStyleNo=-1 then begin
rvs.ParaStyles.Add;
NewStyleNo := rvs.ParaStyles.Count-1;
rvs.ParaStyles[NewStyleNo].Assign(ParaInfo);
rvs.ParaStyles[NewStyleNo].Standard := False;
ParaInfo.Free;
Sergey, I misread, I was pretty sure I read Assign() instead AddFrom()
j&b, You don't have to create the TabList inside the OnParaStyleConversion. You could also create it outside it and assign the list to ParaInfo.Tabs in the OnParaStyleConversion.
Inside the OnParaStyleConversion...
In your button click...
Instead of creating/freeing the list all the times it should be pretty save to keep you own list, create it at startup, fill it with the settings read from an ini-file for instance and assign that list to ParaInfo.Tabs.Assign().
private
{ Private declarations }
FTabs: TRVTabInfos;
case UserData of
PARA_TAB: begin
if Assigned(FTabs) then
ParaInfo.Tabs.Assign(FTabs);
FTabs := TRVTabInfos.Create(nil);
with FTabs.Add do begin
Position := MMToPixels(50);
Align := rvtaLeft;
Position := MMToPixels(120);
Align := rvtaLeft;
RichViewEdit1.ApplyParaStyleConversion(PARA_TAB);
FreeAndNil(FTabs);
