Save to database directly as html
Marco Azevedo
Post by Marco Azevedo »
Dear friends,
I would like to save the text from TRichview to database as html format directly without save in HD. Is there anyway to do that ?
Re: Save to database directly as html
If you want to store to database from TRichView or TRichViewEdit, use SaveHTMLToStreamEx/SaveHTMLToStream method (in the same way as SaveRVFToStream is used in Demos\Delphi\DB Demo\2 RichViewEdit\)
If you want to DBRichViewEdit to store data in a custom format, it's possible starting from TRichView v1.9.13 (available for registered users): OnLoadCustomFormat and OnSaveCustomFormat events.
