Search and Highlight in TRVTableCellData
mamouri
Post by mamouri »
I want highlights searched words in a RichView cell. I write a function for this purpose and get content of cell using TRVItemFormattedData.
When I want search for a text to highlight it, it raise a List Bound exception.
Here is my code:
Procedure TfStory.HighLighting(Cell: TRVTableCellData; Words: Array of String);
  I: Integer;
  D: TRVItemFormattedData;
Begin
  D := TRVItemFormattedData(Cell.GetRVData);
  for I := Low(Words) to High(Words) do
    while D.SearchText(True, False, True, Words[I]) do
      TRVEditRVData(Cell.Edit).ApplyStyleConversion_(tsHighLight, rvscTextStyle, False);
I'm not sure about ths ApplyStyleConversation_ too. And I'm not sure does entered parameter are correct or not?
How is it possible to Search a cell of table and change selected text style?
Thank you
Please use this code instead (assuming that this table is in RichViewEdit1):
var I: Integer;
  rve: TCustomRichViewEdit;
  Cell.Edit;
    with CustomRVFormattedData(Cell.GetRVData) do
      SetSelectionBounds(0, GetOffsBeforeItem(0). 0, GetOffsBeforeItem(0));
    rve := RichViewEdit1.TopLevelEditor;
    while rve.SearchText(Words[I], [rvseoDown, rvseoWholeWord]) do
      rve.ApplyStyleConversion(tsHighLight);
mamouri
Post by mamouri »
Thank you very much. This work only if RichView is formatted. I have lot's of Cells that are written from database and want to highlight some keywords in every of them each time I insert a new row.
In fact I want to access to TRVFormattedData and highlight my keywords there. so it doesn't need a formatted Cell.
Also is it possible to do such with RichView and not RichViewEdit. I mean accesing directly to RichView cell data and highlight some words on that.
Because RichView is much more faster in rendering text than RichViewEdit.
Thank you
mamouri
Post by mamouri »
Here is what I currently am doing:
  //Printing Answer.
  RowNo := FixedTopRow;
  while not DS.Eof do
    with T.Cells[RowNo,1] do begin
      if RowNo mod 2 <> 0 then Color := clCream;
      AddNLWTag(DS.FindField('Text').AsString,tsNormal,-1,-1);
      SetItemExtraStrProperty(0, rvespHint, DS.FindField('QAID').AsString);
      HighLighting(T.Cells[RowNo, 1], [Words]);
      DS.Next;
      RowNo := RowNo + 1;
    end; // with
Words is an array of words that must highlighted.
If document is not formatted, use the following code (the second example in the topic):
http://www.trichview.com/forums/viewtop ... =2485#2485
MarkSubString(Cell, Word)
Note: this code converts strings to ANSI
mamouri
Post by mamouri »
Does it work if I remove following line of code:
          if rvioUnicode in item.ItemOptions then
            s3 := RVU_AnsiToUnicode(RVData.GetStyleCodePage(item.StyleNo), s3);
And convert String variable into WideString?
Is there special reason that you convert unicode to ansi here?
No, it's not enogh.
Give me WideString analog of LastPos function from that demo, and I'll create Unicode version of that procedure :)
mamouri
Post by mamouri »
Yeah. I was forgot about that LastPos function :roll: Here is a minimal LastPos function that support widestrings. It use of anothor function named InternalPosW grabbed carefully :D from DIUtils unit of DIHtmlParser
http://www.zeitungsjunge.de/delphi/htmlparser/
function InternalPosW(Search: PWideChar; lSearch: Cardinal; const Source: PWideChar; LSource: Cardinal; const StartPos: Cardinal): Cardinal;
label
  Zero, One, Two, Three, Match, Fail, Success;
  PSource, pSearchTemp, PSourceTemp: PWideChar;
  lSearchTemp: Cardinal;
  c: WideChar;
  if lSearch > LSource then goto Fail;
  Dec(lSearch);
  Dec(LSource, lSearch);
  if LSource <= StartPos then goto Fail;
  Dec(LSource, StartPos);
  PSource := Source;
  Inc(PSource, StartPos);
  c := Search^;
  Inc(Search);
  while LSource > 0 do
      while LSource >= 4 do
          if PSource^ = c then goto Zero;
          if PSource[1] = c then goto One;
          if PSource[2] = c then goto Two;
          if PSource[3] = c then goto Three;
          Inc(PSource, 4);
          Dec(LSource, 4);
      if LSource = 0 then Break;
      if LSource = 1 then Break;
      if LSource = 2 then Break;
      Break;
      Three:
      Inc(PSource, 4);
      Dec(LSource, 3);
      goto Match;
      Two:
      Inc(PSource, 3);
      Dec(LSource, 2);
      goto Match;
      One:
      Inc(PSource, 2);
      Dec(LSource, 1);
      goto Match;
      Zero:
      Inc(PSource);
      Match:
      PSourceTemp := PSource;
      pSearchTemp := Search;
      lSearchTemp := lSearch;
      while (lSearchTemp >= 4) and
        (PCardinal(PSourceTemp)^ = PCardinal(pSearchTemp)^) and
        (PCardinal(@PSourceTemp[2])^ = PCardinal(@pSearchTemp[2])^) do
          Inc(PSourceTemp, 4);
          Inc(pSearchTemp, 4);
          Dec(lSearchTemp, 4);
      if lSearchTemp = 0 then goto Success;
      if PSourceTemp^ = pSearchTemp^ then
          if lSearchTemp = 1 then goto Success;
          if PSourceTemp[1] = pSearchTemp[1] then
              if lSearchTemp = 2 then goto Success;
              if PSourceTemp[2] = pSearchTemp[2] then
                  if lSearchTemp = 3 then goto Success;
      Dec(LSource);
  Fail:
  Result := 0;
  Exit;
  Success:
  Result := (Cardinal(PSource) - Cardinal(Source)) shr 1;
function LastPosW(const Substr, Str: PWideChar): Integer;
  P: Integer;
  Result := 0;
  P := 1;
  while P > 0 do begin
    P := InternalPosW(SubStr, Length(SubStr), Str, Length(Str), P);
    if P > 0 then
      Result := P;
What's an overcomplicated function :)
I created functions supporting Unicode both in RichView and as a substring to search.
http://www.trichview.com/forums/viewtop ... =5184#5184
mamouri
Post by mamouri »
Thank you man. I'm not even a good grabber 8)
