need to auto-fit table to contents without wordwrapping
MikeP
Post by MikeP »
I need to construct a table in TRichView 19.2 (Delphi 12). I need it to auto-size without word-wrapping the cell contents. what's wrong with my code?
what this code does is a full-width table divided into two very wide columns--completely ignoring the width of the table's contents.
procedure TfrmTRichView_TRichView_AddTable.FormCreate(Sender: TObject);
  Table: TRVTableItemInfo;
  RVData: TCustomRVData;
  iParaStyleIndex: Integer;
  // Assuming you have a TRichView component named RichView1
  RVData := RichView1.RVData;
  // Create a table with 1 row and 2 columns
  Table := TRVTableItemInfo.CreateEx(1, 2, RVData);
  table.BestWidth:=0;
  table.Options:=table.Options - [rvtoIgnoreContentWidth] + [rvtoRTFAllowAutofit];
  // Add a new paragraph style with no word wrap
  iParaStyleIndex := RichView1.Style.ParaStyles.Count;
  with RichView1.Style.ParaStyles.Add do
    Options := Options + [rvpaoNoWrap]; // Disable word wrap
    Alignment:=rvaRight;
  // Apply the style to text inside the cells
  Table.Cells[0,0].Clear;
  Table.Cells[0,0].BestWidth:=0;
  Table.Cells[0,0].AddNL('No Wrap', 0, iParaStyleIndex);
  Table.Cells[1,0].Clear;
  Table.Cells[1,0].BestWidth:=0;
  Table.Cells[1,0].AddNL('No Wrap', 0, iParaStyleIndex);
  // Insert table into document
  RVData.AddItem('', Table);
  // Update document display
  RichView1.Format;
Thank you!
Re: need to auto-fit table to contents without wordwrapping
Your code is correct.
But if you do not specify widths of columns or a width of a table, TRichView will display it filling the whole editor width.
To auto-fit without word-wrap, assign some small value either to table.BestWith, or to BestWidth of all columns.
Like this:
  RVData := RichViewEdit1.RVData;
  table.BestWidth := 1; // this is it, a small width
  table.CellBorderWidth := 1; // to make cell border visible
  iParaStyleIndex := RichViewEdit1.Style.ParaStyles.Count;
  with RichViewEdit1.Style.ParaStyles.Add do
  // in TRichView, Cells have syntax Cells[Row, Column]
  Table.Cells[0,1].Clear;
  Table.Cells[0,1].BestWidth:=0;
  Table.Cells[0,1].AddNL('No Wrap', 0, iParaStyleIndex);
  RichViewEdit1.Format;
A thing to improve: this code will add a new paragraph style each time when it is executed.
Change
to
  var ParaStyle: TParaInfo;
  ParaStyle := TParaInfo.Create(nil);
  ParaStyle.Assign(RichViewedit1.Style.ParaStyles[0]);
  ParaStyle.Options := ParaStyle.Options + [rvpaoNoWrap]; // Disable word wrap
  ParaStyle.Alignment:=rvaRight;
  iParaStyleIndex := RichViewEdit1.Style.FindParaStyle(ParaStyle);
  ParaStyle.Free;
MikeP
Post by MikeP »
perfect, thank you so much!
best regards,
mp
