hello
It´s posible use SynEdit with TrichView?
So i want higligth, source code.
Complex syntax highlighting in TRichViewEdit is not possible yet.
There is a syntax highlighting component in http://www.trichview.com/resources/ , but it can do only a very basic highlighting, and on relatively small documents.
hello "Guest",
Do you have a special application in mind ?
I'm interested in your experience, because I had the same question a few years ago.
Since then I integated both RichView and SynEdit into my application.
But still I'm not satisfied and have plans to build a combined viewer. The application I'm thinking of is html+scripting or doc+code. The idea is that html or doc is edited as wysiwyg (well nearly) in RichView and the scripting/code is handled in SynEdit. Some kind of special items in RichView should act as a placeholder for the code sections.
cheers,
cheers,
RichView, although it's a beatifull editor, is not well suited for code editing.
If you want to make a code editor, you'll need Synedit or Scintilla, because they have good and flexible lexer/parser, code completion, smart tabs, auto-indent, proposals, bookmarks, breakpoints etc, etc.
Codefolding is available in Scintilla. Synedit is working on code folding. There's a guy who already made a code folding in synedit, but it's still beta.
Succes,
Succes,
