Does QRRichView component exist for FastReport in Delphi 10.3?
Leesng68
Post by Leesng68 »
If it exists, how do I get it?
Re: Does QRRichView component exist for FastReport in Delphi 10.3?
TQRDBRichView is defined in RVQRCtrls, located in <TRichView Dir>\ThirdParty\QuickReport\Source\
This class is for QuickReport, not for FastReport.
Sorry, FastReport is not officially supported by TRichView.
For RV+QR integration, there are packages for Delphi from 2007 to 12.x. They expect QuickReport version 6.
If you want to use older version, open <TRichView Dir>\ThirdParty\QuickReport\Source\RVQRCtrls.inc and enable the corresponding compiler $define.
