Inline Images
Inline Images
Good day! Any idea how to include inline images when sending an email using html? The images where added during composing an email using richviewedit.
Re: Inline Images
What components do you use to save HTML email?
We have demos that use Indy, CleverComponents, and Outlook COM object.
Re: Inline Images
Mind sharing here sir? Ill take a look. Thanks a lot.
Re: Inline Images
- Sending HTML emails using Indy: https://www.trichview.com/forums/viewtopic.php?t=11
HTML emails are created as MIME-encoded messages. - Saving HTML emails using CleverComponents: demos are included in TRichView setup, in <TRichView Dir>\ThirdParty\CleverComponents\ folder.
HTML emails are created as MIME-encoded messages. - Sending HTML emails using Microsoft Outlook COM object: https://www.trichview.com/forums/viewtopic.php?t=10734
Images are embedded directly in HTML code. This is not a good solution, because not all email clients support this kind of image representation. For example, GMail does not.
I'll update this demo to use MIME.
Re: Inline Images
Super Thanks So Much Sir! Ill check it out.
