Inserting control into TRichViewEdit
Dmitry Kholl
Post by Dmitry Kholl »
I need use TComponent.Tag property in inserted into editor controls.
I set in Tag property my value.
cbx: TComboBox;
cbx.Tag := -1;
Then I paste control into editor.
rvTemplateForm.InsertControl('',cbx, rvvaBaseline);
And control tag has another value.
Does trichview use the tag propery of inserted components?
Can I disable it?
I have to use the tag property at events of the component.
Yes, TRichView uses tags of inserted controls, and it cannot be turned off.
Suggestion: create a new component inherited from TComboBox with new published integer property, and use it instead.
