Search conception in TRichView
Michael Pro
Post by Michael Pro »
Well, let me explain my trouble.
I'm using TRichViewEdit for my own text processing purposes and I've found out, that text search is working only for exact items, not for some kind of their mixing.
This means, that I can write one word - for example "elephant" - and make part of it in different Text Style - for example for part "pha" I could change text size or font name - it should be a new item after text reformatting.
And this means, that word "elephant" has broken in three different parts - "ele-pha-nt". After that text search won't work for this word.
The situation I've described is common - user could write one sentence, using different styles (and it means, that he implicitly uses different items) - and the text search won't work for this simple situation. He could change styles for whole words - and the text search won't find combination for this sequences :(
How should I manage text searching?
Rob
Post by Rob »
You can concatenate each item while searching and see if that matches the search text.
For example, if you need multiple items to search, keep a 'pointer' to the first item. If that item is not long enough, add the second item and match again. If this is still too shot, keep adding items until the length supersedes your search criteria. If no match, move to the next item, keep a 'pointer' to that and continue as described.
That would most probably do the trick. The code is not too hard to write.
Michael Pro
Rob wrote:You can concatenate each item while searching and see if that matches the search text.
Thanks for a tip.
But here is one big question in algorithmics - for example, we've searching 15-letter string. First item have 5 letters, second item - 4 letters, third item - 7 letters. 16 letters total.
Let's suppose, that in this concatenation there is no existing matches - after it all we've to exclude first item from searching items - and make new concatenation.
It could be concatenation of second, third and fourth items - but... But the searching string could be allocated in some last characters of first item and lasts to some characters of the fourth item.
Well, it's disappointing me, but I've understood that I should implement good searching procedure for my application - it's the only way to make searching through document.
PS
As I've understood for "search-and-replace" routine I need to implement text selection for some found items and simply make text inserting?
And the other one question - if I want to search through selected text, how should I do this the best way? RichView actually searches through whole document, not part of it.
adwilson
Post by adwilson »
Did you try function
TRichView.SearchText(s: String; SrchOptions: TRVSearchOptions): Boolean; ?
Michael Pro
adwilson wrote:Did you try function
Yes, of course. If I didn't use this function I didn't ask this question and didn't post long messages. :)
SearchText routine doesn't work for texts, allocated in different items, as I said. If we apply bold for a half of text, and the other one still stays unmodified, we won't find the whole text with this function, because normal text and bold text are allocated as different items.
Another trouble - text search is working only for whole text, not for part of it.
I am copying message of DavidRM.
The builtin SearchText() function doesn't find words or phrases that cross style boundaries. It's also not very Unicode friendly. This is my attempt at solving both problems.
I've tested it some in my own application, and it seems to be working. It's obviously based heavily on the built in SearchText, but...different.
I'm open to comments, suggestions, and warnings of very bad choices.
type
   TSTUFlag=(stufFromStart,stufMatchCase,stufWholeWord);
   TSTUFlags=set of TSTUFlag;
type
   TSTUItem=class(TObject)
      ItemNo: integer;
      Length: integer;
function SearchTextUnicode(rv:TCustomRichView; const searchText:widestring; flags:TSTUFlags):Boolean;
   function DoSearchTextUnicodeInItem(item:TCustomRVItemInfo; storeSub:TRVStoreSubRVData;
                                      subRVData:TCustomRVFormattedData;
                                      const searchText:widestring):boolean; forward;
   function CheckIsDelimiter(RVData:TCustomRVData; ch:widechar):boolean;
      Result:=RVData.IsDelimiterW(Word(ch));
   function DoSearchTextUnicode(RVData:TCustomRVData; const searchText:widestring;
                                startItemNo, startItemOfs:integer):boolean;
         ii, styleNo, p1, p2, ofs, p1Ofs, ll: integer;
         selStart, selStartOfs, selEnd, selEndOfs: integer;
         paraText, itemText: widestring;
         paraList: TObjectList;
         paraItem: TSTUItem;
         item: TCustomRVItemInfo;
         storeSub: TRVStoreSubRVData;
         subRVData: TCustomRVFormattedData;
         chkText: widestring;
      Result:=false;
      ii:=startItemNo;
      while (ii<RVData.ItemCount) do
         styleNo:=RVData.GetItemStyle(ii);
         if styleNo>=0 then
            // collect paragraph text
            paraList:=TObjectList.Create;
               itemText:=RVData.GetItemTextW(ii);
               if not (stufMatchCase in flags) then
                  itemText:=WideUpperCase(itemText);
               if startItemOfs>0 then
                  Delete(itemText,1,startItemOfs-1);
                  startItemOfs:=0;
               paraItem:=TSTUItem.Create;
               paraItem.ItemNo:=ii;
               paraItem.Length:=Length(itemText);
               paraList.Add(paraItem);
               paraText:=itemText;
               while ((ii+1)<RVData.ItemCount)
                     and (RVData.GetItemStyle(ii+1)>=0)
                     and (not RVData.IsParaStart(ii+1)) do
                  itemText:=RVData.GetItemTextW(ii+1);
                  paraItem.ItemNo:=ii+1;
                  paraText:=paraText+itemText;
                  inc(ii);
               p1:=Pos(searchText,paraText);
               Result:=(p1>0);
               if Result and (stufWholeWord in flags) then
                  Result:=false;
                  chkText:=paraText;
                  ofs:=0;
                  while (p1<>0) do
                     p1Ofs:=ofs+p1;
                     Result:=(p1Ofs=1) or ((p1Ofs>1) and CheckIsDelimiter(RVData,paraText[p1Ofs-1]));
                     if Result then
                        Result:=(((p1Ofs+Length(searchText))>Length(paraText))
                                 or (((p1Ofs+Length(searchText))<=Length(paraText))
                                    and CheckIsDelimiter(RVData,paraText[p1Ofs+Length(searchText)])));
                     if Result then
                        p1:=p1Ofs;
                        Break;
                     Delete(chkText,1,p1+(Length(searchText)-1));
                     inc(ofs,p1+(Length(searchText)-1));
                     p1:=Pos(searchText,chkText);
               if Result then
                  // select in RVData
                  p2:=p1+(Length(searchText)-1);
                  selStart:=-1;
                  selStartOfs:=0;
                  selEnd:=-1;
                  selEndOfs:=0;
                  ll:=0;
                  while (ll<paraList.Count) do
                     paraItem:=TSTUItem(paraList[ll]);
                     if p1>paraItem.Length then
                        dec(p1,paraItem.Length);
                        dec(p2,paraItem.Length);
                        inc(ll);
                        end
                        selStart:=paraItem.ItemNo;
                        selStartOfs:=p1;
                        if p2<=paraItem.Length then
                           selEnd:=selStart;
                           selEndOfs:=p2+1;
                           end
                           selEnd:=selStart;
                           selEndOfs:=selStartOfs;
                           inc(ll);
                              if p2>paraItem.Length then
                                 inc(ll);
                                 end
                                 selEnd:=paraItem.ItemNo;
                                 selEndOfs:=p2+1;
                                 Break;
                        Break;
                  if selStart>=0 then
                     TCustomRVFormattedData(rvdata).SetSelectionBounds(selStart,selStartOfs,selEnd,selEndOfs);
               paraList.Clear;
               paraList.Free;
            end; // try
            if Result then
               Exit;
            end
            item:=rvData.GetItem(ii);
            storeSub:=nil;
            subRVData:=TCustomRVFormattedData(item.GetSubRVData(storeSub,rvdFirst));
            if subRVData<>nil then
               Result:=DoSearchTextUnicodeInItem(item,storeSub,subRVData,searchText);
               if Result then
                  Exit;
         inc(ii);
      Result:=DoSearchTextUnicode(subRVData,searchText,0,0);
      if not Result then
         repeat
            subRVData:=TCustomRVFormattedData(item.GetSubRVData(storeSub,rvdNext));
            if SubRVData=nil then
               Break;
         until Result;
      if Result then
         item.ChooseSubRVData(storeSub);
      storeSub.Free;
      useSearchText: widestring;
      startItemNo, startItemOfs, sl, so: integer;
      useSearchText:=WideUpperCase(searchText)
      useSearchText:=searchText;
   item:=nil;
   storeSub:=nil;
   if not (stufFromStart in flags) then
      item:=rv.RVData.GetChosenItem;
      if item=nil then
         item:=rv.RVData.PartialSelectedItem;
      if item<>nil then
         subRVData:=TCustomRVFormattedData(item.GetSubRVData(storeSub,rvdChosenDown));
         if SubRVData<>nil then
            Result:=DoSearchTextUnicodeInItem(item,storeSub,subRVData,useSearchText);
            if Result then
               Exit;
   if (stufFromStart in flags) then
      startItemNo:=0;
      startItemOfs:=rv.RVData.GetOffsBeforeItem(startItemNo);
      end
      if rv.RVData.SelectionExists(true,false) then
         rv.RVData.GetSelBounds(sl,startItemNo,so,startItemOfs,true)
         startItemNo:=rv.RVData.GetFirstItemVisible;
      if startItemNo<0 then
         startItemNo:=0;
   if startItemNo>rv.RVData.Items.Count then
      Exit;
   if rv.RVData.Items.Objects[startItemNo]=item then
      inc(startItemNo);
      if startItemNo>rv.RVData.Items.Count-1 then
         Exit;
   Result:=DoSearchTextUnicode(rv.RVData,useSearchText,startItemNo,startItemOfs);
-David
Edit: Fixed issue with repeated function calls.
Michael Pro
Sergey, thanks a lot for this post - I'll test this code immidiately.
As I said, I've got another one question - what is the best way for making search in the selected text? Should I create another one Richview object and place the selected text there, or is where more elegant algorithm exists?
Maybe it's better to simply check ranges of selection without creating another one Richview object?
PS I've examined this code and understood the best way to make search in selected text :) If this code works fine, it'll be great :)
Thanks once more :)
You can place caret at the beginning of the selection, the search will start from there. If the found word will be beyond the other bound of the original selection, return the selection back to the previous state (use functions from RVLinear to store and restore selection)
Michael Pro
Sergey Tkachenko wrote:You can place caret at the beginning of the selection, the search will start from there. If the found word will be beyond the other bound of the original selection, return the selection back to the previous state (use functions from RVLinear to store and restore selection)
I'm so grateful for this help. In first view everything works OK. I didn't thought, that I could implement good searching in such easy way. Especially I want to thank DavidRM for contributing great searching routines.
By the way, I've found that SearchTextUnicode didn't always make right selection in RichView Edit (sometimes selection isn't highlighted) - but I've solved this problem with simple applying of Refomat procedure - and after that everything works fine.
Reformat is an overkill here. Use Invalidate.
Michael Pro
Sergey Tkachenko wrote:Reformat is an overkill here. Use Invalidate.
ОК, rewrote this part.
I've got another one advice for this code - actually, I didn't find implementation for directional search, but I've done it directly in my processing procedures. If you gonna implement this contributed procedure for text searching in futher versions of TRichView, it could be useful to implement all the search options from Delphi search dialogs for example (and it'll be more MS Word like search conceptions).
This means, that the full list of options in ideal looks like:
a) Case sensitive option (implemented in this code)
b) Match case (implemented in this code)
c) Searching in entire scope/from cursor (partially implemented)
d) Searching in selected text/global search (not implemented - an due to this c) state won't work correctly in all cases - I've to make some adjustments to the contributed code and fix it in my inherited class - it didn't look so nice in object-oriented view :( )
e) Direction of search - it's Achilles' heel of this code (not implemented). Without code corrections, I've done it with cycling through desire part of searching and keeping information of last found item. If the search routine couldn't find the right text, I'm simply restoring the last backup information. It's not looking nice for implementing "Find Next" method, but another way for making this functionality is to rewrite the DavidRM contributed procedure. This means that in the most bad situation it'll work with O(n!) complexity (but the sequent search has O(n) complexity :( ). Of course, in future I'll optimize my code and fix this slow part for searching, but not for now.
Despite all this disadvantages I've understood that another editors/viewers are far behind from your components, and if this functionality, described above, could be implemented in further versions, it would be outstanding.
With best regards :)
Michael Pro
Big Bug in this code.
For example we are searching word "Search" in following text:
Search text Search.
First time procedure works fine and selects the first "Search", but if we're applying search again, selection goes wrong.
Why? Because deleting the first found selection from a part of searching text affects on calculation of offsets for futher searching - and the procedure will find wrong offset (it'll mark " text " because it deletes word Search from the first sentence and starts offset from zero).
Michael Pro
Well, I've found this bug. It's related to wrong offset calculation if another search text part is located in the same item
         paraItem: TSTUItem;
         Deleted: Boolean;
         OldOffset: integer;
         OldItem: Integer;
      Result:=false;
      Deleted := false;
      ii:=startItemNo;
      OldItem := startItemNo;
         if styleNo>=0 then
                  //Check here
                  if ii = OldItem then
                    Deleted := true;
                    OldOffset := startItemOfs - 1;
                  startItemOfs:=0;
               paraText:=itemText;
                  inc(ii);
               Result:=(p1>0);
                  Result:=false;
                  chkText:=paraText;
                  ofs:=0;
                  while (p1<>0) do
                     p1Ofs:=ofs+p1;
                     if Result then
                     if Result then
                        p1:=p1Ofs;
                        Break;
               if Result then
                  // select in RVData
                  selStart:=-1;
                  selStartOfs:=0;
                  selEnd:=-1;
                  selEndOfs:=0;
                  ll:=0;
                        inc(ll);
                        end
                        selStartOfs:=p1;
                           selEnd:=selStart;
                           selEndOfs:=p2+1;
                           end
                           selEnd:=selStart;
                           inc(ll);
                                 inc(ll);
                                 end
                                 selEndOfs:=p2+1;
                                 Break;
                        Break;
                  if selStart>=0 then
                     //Check here
                     if Deleted and (OldItem = selStart) then
                       if selStart = selEnd then
                           selStartOfs + OldOffset, selEnd, selEndOfs + OldOffset)
                           selStartOfs + OldOffset, selEnd, selEndOfs);
                     end
               paraList.Clear;
               paraList.Free;
            end; // try
            if Result then
               Exit;
            end
            storeSub:=nil;
               if Result then
                  Exit;
         inc(ii);
I've marked changes with
//Check here
It could be useful for those, who could apply this routine in their projects - but it should be properly tested - actually, I could add another bug with my changes :-)
Michael Pro
In part, there we making text selection, we need to check, if the search text was found in the start item or somewhere else.
If it's allocated in the start item, then we have to modify offsets - and check the following:
a) If the search text whole allocated in the start item - need to modify start AND end offsets - it have been calculated wrong;
b) If only a part of text located in start item - then need to modify only a start offset, NOT the last one - because the last one have been calculated right.
Michael Pro
Another found trouble is an endless cycle, while implementing something like "Replace All" method. If we call this procedure for replacing A for AA - it'll generate an endless changes.
Fixed variant here
   item:=nil;
   storeSub:=nil;
      if item=nil then
      if item<>nil then
            if Result then
               Exit;
      startItemNo:=0;
      end
         {Check here}
         //startItemNo:=rv.RVData.GetFirstItemVisible;
         //startItemOfs:=rv.RVData.GetOffsBeforeItem(startItemNo);
           startItemNo := CurItemNo;
           startItemOfs := OffsetInCurItem;
         startItemNo:=0;
      Exit;
      inc(startItemNo);
         Exit;
As you see, trouble is here
I've changed it for
And it seems to work fine.
But I understand, that I using search routine for text only (I didn't make good graphics support in my inherited Editor), and so, correctness of this code is needed to be examined and tested.
