Removing Page break
ChristopheA
Removing Page break
Post by ChristopheA »
Hi there,
I tried using to remove Page break:
While reText.SearchText(#12, SearchOptions) do
        reText.InsertText('');
but it does not work, any idea?
(reText is a TRichViewEdit)
Page break is not stored as character, so it cannot be found using SearchText. Page break is an item property.
If you need to remove all page breaks, and it should not be an editing operation, the code is:
for i := 0 to reText.ItemCount-1 do
  reText.PageBreaksBeforeItems[i] := False;
If it must be an editing operation (that can be undone by users), the code is:
  if reText.PageBreaksBeforeItems[i] then begin
    reText.SetSelectionBounds(i, reText.GetOffsBeforeItem(i),
      i, reText.GetOffsBeforeItem(i));
    reText.RemoveCurrentPageBreak;
ChristopheA
Works fine, thanks :D
