Table Inside a Table
Joel Cuyos
Post by Joel Cuyos »
The code below works fine if the table in question is located directly on the Editor. If the it is located in a table cell, that's a problem..
if ChartEditor.GetCurrentItemEx(TRVTableItemInfo, RVE, Item) then
Table := TRVTableItemInfo(item);
ItemNo := Table.GetMyItemNo;
ChartEditor.TopLevelEditor.SetSelectionBounds(ItemNo, ChartEditor.TopLevelEditor.GetOffsBeforeItem(ItemNo), ItemNo, ChartEditor.TopLevelEditor.GetOffsBeforeItem(ItemNo)); <-- error on this line
Any help is appreciated
If the caret is inside table cell, ChartEditor.TopLevelEditor is an inplace editor of this cell.
The editor containing table is returned in RVE:
  RVE.SetSelectionBounds(ItemNo, RVE.GetOffsBeforeItem(ItemNo),
    ItemNo, RVE.GetOffsBeforeItem(ItemNo));
Joel Cuyos
Thanks Sergey
