Hi there,
I have a RTF text that include a delta symbol (∆), when I try to display it in RichView I get a question mark (?)
any idea what is going on?
Delta symbol appears as a question mark
Ok. If Delta was from Arial font, and I guess it was inserted as Unicode character in RTF. So this character can be loaded correctly in 2 cases:
1) Language of this RTF file is Greek, and it will be loaded in GREEK_CHARSET
2) You can use Unicode, assigning RichView.RTFReadProperties.UnicodeMode to rvruOnlyUnicode or rvruMixed. In the former case, all text from RTF will be loaded as Unicode. In the latter case, only this Delta character (and characters like it) will be loaded as Unicode, the rest of text will be loaded as ANSI.
