Problem with image links when importing/exporting RTF &
simon-c
Post by simon-c »
I've followed one of your examples elsewhere for saving an image as a link. The image is inserted into RVEdit and when the RTF is saved I trap OnSaveItemToFile, use RVData->GetItemExtraStrProperty(ItemNo,rvespImageFileName... to get the filename and write out RTF with
OutStr="{\\field{\\*\\fldinst INCLUDEPICTURE \""+Loc+"\" \\\\d }}";
This works great.
When the RTF is loaded back in to RVEdit with LoadRTFFromStream I trap OnImportPicture, load the picture passed through in Location and all is well.
The problem then comes that if the user saves this file as HTML when I trap OnHTMLSaveImage the original link is not available in rvespImageFileName so at this point the image is lost.
I tried setting rvespImageFileName myself during OnImportPicture, but I can't figure out which item number to set it on, as ItemNo isn't passed through to this call.
Is there any way to fix this issue?
Many thanks
Simon.
Do you mean that value of this property is lost when you load RTF file?
Set RichView.RTFReadProperties.StoreImagesFileNames = True
simon-c
Post by simon-c »
Sergey Tkachenko wrote:Set RichView.RTFReadProperties.StoreImagesFileNames = True
That was the setting I'd missed. Thank you.
Simon.
