How to get all the text(items) from TRichViewEdit (unicode)?
Bonny
Post by Bonny »
I am trying to get all the text from TRichViewEdit in Unicode.
The only function I found is:
GetCurrentItemTextW
But it only gives the line where the caret is located.
Without moving caret, is there some way to get all the lines? (all the items?)
I tried to use GetTextBuf but this doesnt return Unicode, but a translation to some codepage (which I don't want).
Thank you for your help,
Bonny
Bonny
Post by Bonny »
I found a solution here:
http://www.trichview.com/forums/viewtopic.php?t=1527
Is there also a way to get the unicode text for each text line, without placing cursor? (So using some index)
Regards
Bonny
In any case, it would be unefficient. It's better to get the whole text and extract lines from it.
