List index out of bounds problem
jimmaguire
Post by jimmaguire »
In RVClasses, TRVIntegerList, Get line 269. It happens when the user selects a range of a column and then changes the font using the standard font dialog. The new extended worked fine.
I've sent a sample rvf and print screen of the problem in a separate email.
jimmaguire
More information
If you edit the rvf in TRichViewEdit, it does not show the odd page break until you do a print preview.
Please send bug reports directly to ilya at trichview dot com
In this way they will be answered faster.
proxy3d
ScaleRichView Developer
Post by proxy3d »
Error is corrected.
