Page Orientation Not Saved
Shane Stump
Post by Shane Stump »
The page orientation isn't saved.
This is demonstratable by
1) Loading the Readme.rvf into the ActionTest.exe
2) Change the orientation from portrait to landscape
3) Save it.
4) Close ActionText.exe
5) Reload ActionTest.exe
6) Load Test.rvf
The orientation will be portrait.
Best Regards,
Shane
proxy3d
ScaleRichView Developer
Re: Page Orientation Not Saved
Post by proxy3d »
Оrientation of the page is not saved in file RVF.
We see as possible solve a problem.
Shane Stump
proxy3d wrote:Îrientation of the page is not saved in file RVF.
I am not quite sure I understand your answer. Are you saying that it is a problem you have identified and are fixing?
If not, how do I fix it? My customers are going to expect ALL page setup to be saved per document.
Best Regards,
Shane
Currently, ScaleRichView does not save additional information in RVF. The same information as from TRichView is saved.
Yes, I agree, we must decide how to save page info.
Probably, at least in the first version, it will be saved in DocProperties. The solution will be this week.
You can save additional information in DocProperties yourself, but it's better to wait several days until we suggest a "standard" solution.
Shane Stump
I will put my testing on hold until y'all have it done.
I understood TRichView not saving page properties, but I honestly can't understand how that feature could have been left out of TScaleRichView as without it, the difference between the products is blurry.
Best Regards,
Shane
proxy3d
Post by proxy3d »
See update v1.2.8.
